I'm planning on a piece of 18 ga sheet metal to cover the whole area. It will need some reinforcing ribs welded to the bottom side to give it some strength and to cut down on vibrations.The gas tank has the pressure line, return line and vent line all coming out of the top of the tank at a 90 degree angle. I need to put a spacer of about 1" and probably a thin hard board on top of that to protect the lines from damage from trunk usage. Polystyrene (Styrofoam) and gasoline are the primary components of Napalm so I'm not using that. What has any else used as a spacer?
Any update on this?The gas tank has the pressure line, return line and vent line all coming out of the top of the tank at a 90 degree angle. I need to put a spacer of about 1" and probably a thin hard board on top of that to protect the lines from damage from trunk usage. Polystyrene (Styrofoam) and gasoline are the primary components of Napalm so I'm not using that. What has any else used as a spacer?
The top of the tank is sealed and I used hardline from the connections. I could not find urethane so I used styrofoam with an 1/8" hardboard on top. It has worked perfect plus it gives extra sound insulation. The rubber trunk mat fit back in fairly well as did the spare tire, jack etc. The more I thought about the danger of using styrofoam would more than likely come from a severe rear end collision. I can easily remove the hardboard and foam to access the tank if I would need to.Any update on this?
Where did you find the PVC board?I made / lined my entire trunk area with 1/2 inch thick PVC board. Comes in 4x8 sheets - near any color.. I used black then covered with trunk carpet. Impervious to gas and most chemicals.
Did you have to put anything around or on top of the tank or does the pvc board not flex at all?I made / lined my entire trunk area with 1/2 inch thick PVC board. Comes in 4x8 sheets - near any color.. I used black then covered with trunk carpet. Impervious to gas and most chemicals.
