Hi,
I am installing an air conditioner in my '66 convertable soon. I live in Phoenix, AZ. So, I am planning on installing a good electric fan to keep my 289 cool while at idle in the lovely Phoenix traffic.
I need a good recommendation on a fan I can count on to do the job.
Does anyone have any suggestions and where to get the fan.
I want something specific for a Mustang that will bolt right on without a lot of fabrication of brackets, etc.
Thanks a lot for your time,
John Thomas
65 coupe pictures: http://albums.photopoint.com/j/AlbumIndex?u=525545&a=3848066
66 Convertable pictures:http://albums.photopoint.com/j/AlbumIndex?u=525545&a=7533002
Hot Rod Air makes a system I own one and like it. Flex-a-lite also makes one. I believe they both drop in. The Hot Rod Air system includes a tie in to the A/C clutch and spins the fan when the A/C is on. Check out some pictures at the site in my profile.
Good luck
http://albums.photopoint.com/j/View?u=1571478&a=12287439&p=44845480.jpg
Also take a look at SPAL fans, in my opinion much better quality than flex-a-lite and perma-cool etc. I found them cheapest at a place called Haywire, www.haywireinc.com , in fact it was hotrod air that told me what fan I needed (the SPAL dual 11" with shroud) but they were about $100 more expensive. You can see the result of the fan going in my 69 on my website, cooling-wise it is a massive improvement.
69 Sportsroof, 351C, 4spd toploader, Restomod BOSS 429 clone - the one and only (?) 1969 BOSS 351
http://home.swbell.net/boss351/mustang/boss1.jpg
http://stangnet.cardomain.com/user/adamg69
The '65-'66 HRA electric fan uses a single Tri-Pac fan, not a Spal like the later ones. Tri-Pacs are queiter, but don't flow as much air as the spal and may not have quite the life, but are still decent fans. I have the HRA fan, although I haven't installed it yet. It looks to be decent quality, although the mounting brackets are flimsy.
http://albums.photopoint.com/j/View?u=1572917&a=11954864&p=42994554.jpg
The SPALs on my car are pretty loud but that is easily fixed, louder exhausts! :)
I live in Houston (goes to show High Heat and Humidity your Honor), and installed a perma-cool 16" electric fan. I bought it because it was made in the USA. It was easy to install (about 1 hour). I wanted to: a. cool better and b. free up some horsepower.
Results:
a. my fixed blade fan cooled by about 50% better
b. no really noticible horsepower improvement, not worth sacrificing the coolness of the engine anyways.
Hope that helps.
