Yet another simultaneous problem as I get into the 5th week of "not gonna turn this car into a project" (!).
1966 convertible with 302.
Since I am adding AC, I decided to install a shroud and 16" electric fan.
I have a 4-core Champion radiator, stock 16" width.
With my first attempt, the fan I got was too thick (measured about 3 3/8" thick, conflicting with the shaft of the water pump with about 5/8" overlap).
So I got a thinner fan, and darn, in the trial fit in the rain last night, it JUST BARELY clears the nose of the water pump shaft by about 1/8".
1. Knowing the engine is going to vibrate even the the fore-aft direction, does anyone have any experience with this close a fit between electric fan and water pump (1/8" clearance)?
2. How much clearance would be considered safe?
3. Is it worth grinding down the shroud by 1/8" for the extra millimeters, or should I go for one of the thinnest SPAL 2" slimline fans?
4. ...or should I just shuck the shroud and make it easy, and just mount the fan directly against the radiator? Love that aluminum shroud, though.
5. ...or should I just shuck the radiator etc, and buy a 3-core/shroud/fan combination that fits without fiddlin', and sell my present 4-core rad and shroud/fan.
