In the attempt to get my 66 f/b road worthy, I was trying to track down some odd light behaviour and I discovered that my firewall is not grounded even though I have a heavy gage wire to it. More to the point, I can get over 12 volts at the block and cable at the firewall but on the firewall itself I get no reading on the volt meter. Do I need to scrape the paint off? Never thought that standard paint was much of an insulator.
TIA
If you bolt to an existing painted hole, you may not scrape enough paint while tightening the hardware. To ensure a good connection, you should scrape off the paint and use a star washer under the nut.
Thanks, I'll give it a try tonight with I get home. I'm still suprized that a little paint works as a sufficent insulator.
Don't be surprised. You need metal to metal contact for good connections, which is why your bullet connectors are such a pain in the ass to get apart. Electrons prefer the easiest route, and if there is another way, they will find it! Darn little buggers, those electrons.
