·I have a '66 hardtop six cylinder chassis with a c code 289 warmed up with a autolite 1958 670 cfm, wiend dual plane dome, headers, 2 1/2 inch duals, electric fuel pump, and a couple of other upgrades.
When I signal left no problem. When I signal right both rear tail lights flash. Also, when I apply the brakes the right indicator light on the dash lights up as does the front right signal light.
So far I have replaced the signal light switch assembly,all bulbs, flasher unit, checked most of the wires for shorts and grounds. No luck, still the same problem. Any suggestions would be greatly appreciated.
