·Guest
I wasn't clear in my previous post:
Something is draining my battery.
I have tracked the problem down to the RH tail-light.
Putting an ammeter in line with the battery indicates that if I pull the orange wire with blue stripe,
FROM THE TAIL-LIGHT the drain ceases.
With this wire disconnected, I do not have a RH turn signal or brake light.
I have replaced the tail-light housing and the bulb but still have the problem.
I am stumped. Where do I go from here?
What should I check next?
I also do not see a drain if I remove the bulb from the socket.
Dangerous Dave
Red 64 & 1/2 Coupe
Dangerous Dave
Red 64 & 1/2 Coupe
