Gents,
I got my '70 back from the body shop (fixed major wreck damage and painted car) and there are a few electrical problems that need straightening out.
-parking lights/front turn signals don't work
-when headlights are on, both dash lights for the turn signals light up solid and don't blink, whether turn signal is on or off
-interior lights don't come on
-hazard switch doesn't work
The turn signals work fine when the headlights are off.
Could this be a faulty turn signal switch or headlight switch, or is it something more hellish?
Thanks,
Joseph Knight
My only guess would be a headlight switch, it's the only common denominator(that I can think of) between all of those circuits. You should probably get a few more opinions before taking my opinion on it, but that's the only thing I can think of.
Check your bulbs and make you don't have a 1156 in where a 1157 should be or vice versa. Sounds like a feedback problem.
Sluggo
This won't be all of the problem but you might want to check electrical contacts at light bulbs, parking light bulbs, etc. When mine came back from painting some of the contacts got paint on them and by cleaning up the contacts fixed my problems. Good luck.
When mine came back from painting some of the contacts got paint on them and by cleaning up the contacts fixed my problems. Good luck.[/quote]
What did u use to clean it with
thanks jerry
