Electrical question.
2305 Views 66 Replies 12 Participants Last post by  Snulma1
I have an electrical problem I’m trying to wrap my head around.
Dissasembled my dash to replace my gauge cluster, redo the radio, repaint, and then replace my heater core and wiring.
Swapped out the gauge cluster, and tested the lights with them all working. Then plugged back in the wiper switch and seated cluster as well as screwed in.
Went to check the cluster one last time and they lit up but then went dark.
Thought that may be the battery was low, so pulled it out and placed on a charger for two hours. Placed back in and the lights lit up and the wipers worked but then everything clicked off again.
I’m assuming there’s a short somewhere but not sure where to start. Does anyone have any suggestions?
41 - 60 of 67 Posts
Exactly WHAT stops working properly when you have your issue? Just the instrument cluster illumination or more?
The marker lights and the cluster don’t work when the headlights are on.
When you say "marker" do you mean the front side marker lights or the front parking lights? The front parking lights do NOT work with the headlights, only in the "PARK" (1st) position. If the cluster lights work in the "PARK" position but shut off when you pull the switch to the "HEAD" position then either the switch is defective or the plug is wired improperly.
Sorry I meant the parking lights.
So since the cluster turns off when in the head position, and we tested the switch and it has the proper continuity it must be a wiring issue right? Any tips on figuring out where the issue lies?
Check that the BLU/RED wire is properly located in the headlight plug in the slot matching up with the "I" position. If it IS, examine the rheostat and its contacts that something isn't moving when the switch is pulled out all the way.
Rheostat makes good contact through CW and CCW rotation and into contact point. I looked at the Blu/Red wire and it’s seated properly with a clean contact point.
If I follow the discussion properly, you have an open in the wire somewhere in the highlighted area. Disconnect battery cable, with headlight switch on you should have continuity (almost 0) between A (or B) and R. Where are you located? depending on where you are I or someone I know may be able to help you. I'm in NC.
Rectangle Slope Font Parallel Number
See less See more
Just to make sure I understand, if I use ohmmeter on the wiring harness for the light switch and test between A(or B) and R I should have continuity?
I live in northern NJ. Anyone near and willing to help would be appreciated!
What does "R" have to do with things? That's the rear tail lights which, I believe, work fine. I though the issue was the instrument cluster lights, which is "I", and which the OP already tested, above and which stop working with the switch in the "HEAD" position even though a "bench test" shows continuity.
I’m still at a loss. Looking under the dash there are definitely a couple of wires that are unplugged, don’t know if that’s the issue, hard to trace many of them.
Colors?
If most of your wire harness is original, the color coding is well documented, and can save you a lot of time.
Before you go moving wires around, though, I’d try to clean the switch. It’s a really robust, old-school-tough part, but it’s had over 40 years to corrode. Mine was doing a similar, but not exactly the same, thing as yours, and it works perfectly after a cleaning.
Get a can of this-
Pull the knob (there’s a spring-loaded button on the passenger side of the switch body that releases the knob to come all the way out).
Give a 1-2 second shot directly in the hole you pulled the knob out of, and then another 1-2 second shot on the rheostat path - you’ll have to pull the instrument cluster to see it, it looks like a long coil spring mounted on about half the circumference of the white plastic tumbler that rotates when you turn the knob.
As soon as you spray those two parts, spend a full minute or two pulling the knob in and out and rotating it through its full travel. Don’t skimp on the full minute or two, you’re scrubbing the contacts on each other and it needs the time and repetition for the solvent to work.
Wait a few more minutes, hook the battery back up and give it a try.
That Deoxit is made for exactly this sort of part. I’ve used it to fix “broken” 50 and 60 year-old guitar amps that just had corroded contacts.
It may not solve your problem, but it’s a good, safe place to start.
See less See more
Cleaning the crud off the wires may help a little....
I’ll do my best but it’s not crud. It’s paint since the previous owner sprayed spray paint to cover things
"Goof Off Professional" works wonders. So does GoJo (without pumice).
I tried to use a Mr clean magic eraser and got this.
Gesture Finger Thumb Gas Cable
Bag Luggage and bags Eyewear Wire Electrical wiring
Audio equipment Vehicle door Gadget Eyewear Automotive exterior
Automotive tire Tire Motor vehicle Finger Hood
See less See more
4
Yellow is 12v hot. Blue w/red tracer are instrument cluster illumination. Could be a console feed lead... yellow for the "cubby" lamp, others for shifter illumination and ?
This "triple tap" with Black/Yellow is a switched ignition "hot" for accessories.
Black w/blue tracer are courtesy lights. Probably for the under-dash courtesy lamp(s)?
This is the instrument cluster illumination accessory tap.... accessories that need illumination with dimming capability can be plugged in here.
See notes above each photo.
Great. So none of these should be the reason for my cluster not illuminating while the headlights are on.
Sorry....
Find that red tap with the BLU/RED wires and stick a test light into it. If you get a test light but no dash lights you can assume (I know, I know....) that the problem may be the cluster connector or "printed circuit".
41 - 60 of 67 Posts
