So today i finished putting the plumbing into my car and wired the Hei distributor and my mini starter. when i turn the car on to the acc position the starter and motor starts cranking. on the directions for the starter i says to move the starter cable over on the solenoid so it is with the positive battery cable. last time i checked i only want the starter cranking in the run position. please let me know whats goin on here. any thing will help, (5.o, mini starter, hei dist,)
thanks, matt
The cable should go to the side with the + cable, that is correct. There is another smaller wire from your starter though, correct? That other wire(for the relay on the starter) will go to the other side of the starter solenoid.
