Electrical Weirdness?
411 Views 4 Replies 2 Participants Last post by  Guest
Starter is acting weird. Works fine in am but just sits there buzzing when I start it hot. I suspect the battery but I did the "ol' short check" by disconnecting the positive and hooking up my test light between the loose cable and the battery post. The light lit about 1/2 bright then faded out. I was able to get it to repeat about 4 or 5 more times, the same thing.
What is this, the radio memory or clock? Or?
Thanks.
J. Boggs
You have any timed relays in the car, such as seat belt lights? That's the only thing I can think of...
Didn't want to say but this ain't a Mustang. Wife's Benz.
Has a few idiot lights but I'm checking the battery in the trunk-Hey, didnt' think, might be the trunk light-I can't remember if there even is one-gotta go check. Wouldn't slowly go out like that would it? Only takes about 1 second to go out.
J. Boggs
Gettin weirder. I have an alligator clip hooked to the positive cable (disconnecte from the battery). I touched the light end to positive terminal and it glowed slightly then went out. A couple more times but it didn't light.
I then touched the negative terminal with the end and it lit then went out, two more times same effect.
That can't happen can it? Doesn't there have to be a positive hooked up? I am sure that there is nothing touching by accident.
J. Boggs
did you check your grounds becuase i was getting the same effect in my mustang i would get power throw my grounds sounds weird but if you do not have a good ground weird things happen
