1 - 10 of 10 Posts
How much weight needs to go in a 65 door if its just a shell to make sure it all lines up after it‘s complete..
You could wrap the glass and set it down inside it and that would be pretty close
I thought when i weighed mine it was around 25 lbs
ken
door shell or loaded door?
Thought OP question was what's the contents weight total "going inside a door"
Is it that much" yea maybe that much or close
contents
easy way it to assemble the door and align it before you put the fenders back on.
that is how the factory did it.
ken
If the door changes alignment with 5-10# of weight difference I think you need new hinges.
I believe that Fantom Works owner Dan Short said they used 15 lb sand bags in the doors.
1 - 10 of 10 Posts
