1 - 1 of 1 Posts
It's time to start making space. See below for complete list of everything I have available. I have pictures of everything and can take more on request. Either PM me, email ([email protected]) or text 401.301.3144 with what you're interested in and a zip code and we can work something out from there. Let me know if you have questions. FYI I'm 20 mins north of Boston, MA.
  • JBA Stainless/Ceramic coated mid length headers (dimpled to fit factory power steering box) – P/N 1650SJS - (used)
  • Driver side headlight bucket (original)
  • 65-73 Rear Lead spring bushings (new)
  • Manual steering center link (new/painted)
  • 67 mustang engine cross member (original)
  • Rebuilt Bendix power steering control valve with hoses (gently used)
  • Borgeson power Steering hoses p/n 925107 (new)
  • Borgeson Rag Joint p/n 990016 (new)
  • Aluminum power steering pulleys for Saginaw style keyway pump - new, 2 available
  • 2 sheave water pump pulley (original)
  • Shock tower support braces (original)
  • 200 I6 accelerator bell crank assembly (original/painted)
  • 200 I6 power steering pump mounting bracket (original)
  • 67 FoMoCo grille egg crate assembly - original
  • 67/68 Wide lip grille moldings – repro driver, original passenger
  • 67/68 Grille mounting clips (narrow/outer molding) – (new)
  • Turn signal hood light housing gaskets (new)
  • 68 Gas cap – original
  • 65-72 Scott Drake Mustang Fender/Trunk Letter set – new
  • 67/68 Tail Light Lens Gaskets - new
  • Brake line distribution block – original
  • Power Steering Pump aluminum mounting bracket - original
  • Power steering pump to engine steel mounting bracket - original
  • 200 I6 motor mounts with brackets (original)
  • Rear shackles with bolts (original)
  • 289/302/351w water neck/thermostat housing
  • Cylinder head alternator mounting bracket/spacer
  • Parking brake assembly (dash mount, no handle or cable)
  • 289/302/351w passenger side timing bracket (original)
  • 289/302/351w aluminum timing cover (painted in POR-15)
  • 351w cam retainer plate with screws (original)
  • 351w engine lift hooks (mount to cylinder heads)
  • Flex A Lite aluminum belt driven clutch fan – 6 blade – (new)
  • 64-70 Rear Passenger Floor Pan Patch Panel - new
1 - 1 of 1 Posts
