I just purchased this mustang 289/c4 and I think it turns over a little hard. I noticed that the plate between the engine and transmission is not there. Could this be causing the starter to engage to deep? Is there a problem if this plate is not installed? Thanks for the help TCT
The plate helps align the starter to the bellhousing. Yes it could cause the engine to crank over slow. Try 2 flat washers between the transmission and starter to space the starter away from the flexplate slightly.
Check the timing..if it's to advanced it will cause a very slow cranking condidtion
