Guys,
I've completed everything on my engine now and it is ready to reinstall once the engine bay work is complete.
Two simple questons:
1. When I look into my t-stat housing and see my theromostat, should I be looking at the spring or the other side (with the housing on the engine, upper radiator hose disconnected)?
2. Distributor reinstalation question. I took the distributor back out last night. I installed the left v/c. Put in 5 quarts of 10W40. Then I used my oil pump primer on my Makita spinning CCW. I ran the drill a while, then turned the engine over 1/4 turn, then ran it a while, over and over until I'd spun the engine 5 or 6 times. Then, I watched the intake valve. Once it opened and then closed, I turned the crank CW (looking from the front) until the TDC mark matched the pointer on the timing cover. Then I installed the right v/c (as the oil was starting to make a mess). Then I kept on spinning the crank 1/4 turn at a time while running the oil pump until I made EXACTLY two more revolutions. Then I installed the distributor such that the electrode on the rotor is just beginning to come under the #1 terminal. Is that right?
If those two items are OK, then I'm stuck waiting on an order from Eastwood, and then it will be on to sheet metal repairs in the engine bay. That'll give me about 3 evenings to go on "SWMBO Patrol" and get all that crappy house stuff out of the way so I can have more time to work on the car. I'm pushing the car project as hard as I can, because we are expecting the second week of April. That's going to make it A LOT tougher to spend 3 or 4 hours a night in the barn. I suppose many of you can relate /forums/images/icons/wink.gif.
Phil
'65 Convertible (with many mods.)
http://www.blueriver.net/~finite/Pony.htm
Phil
