I pulled the plugs and # 8 was Black were as the others were a light brown. I ran a compression test and it was good. So Russ my be right when the push rod snapped it did damage to the valve guide causing oil to pass into the cylinder? If so I guess Ill be pulling it apart again. Any Idea on a cost to fix the valve guide? I going to try not to get ripped off. If you guys have any other Ideas that could cause this problem Please let me know. One thing I did find when pulling the plugs was that plugs 1,2,3 and 4 were all loose and had not been tightened. I guess the expert I payed to help me slipped!
Thanks for all your help
Paul
67 prostreet coupe
http://albums.photopoint.com/j/AlbumList?u=1606258
Paul
67 prostreet coupe
