I purchased a 65 a code mustang and an extra motor came with it.I was told it was the original how can i tell? I
have the numbers off of the block they read c4oe-6015c and
it has flat top pistons.Any help would be greatly appreciated. thanks mark
sound like an a code to me, my engine is out of a 65 a code and it had flat top pistons with no valve reliefs. and the c4 in the part number indicates the block was made in 1964
C4OE-C is a 5 bolt bell housing 289
Mine reads: C5AE-6015F
Can you tell me what that is? ( 65 c-code convert. )
I don't see a C5AE-F listed
C5AE blocks were the first of the 6 bolt bell housing 289's
Adjacent to the casting number is a build date code. The engine build date should precede the vehicle production by no more than approx 6 weeks (IIRC, correct me if I'm wrong). I may also be wrong, but I would think a 5-bolt bell would be either a C or D code engine and that the A-code would be a 6-bolt bell?
Are you saying that it is not the original engine/block??
(How do I post a pic? )
