Hello,
Last night I took out the vacuum guage to get some readings and I removed a rubber cap from a connection port on the base to connect the vacuun guage.
Anyways, when I removed the rubber cap the engine RPM's climbed much higher. I thought that if I removed a cap from a carburetor port the engine idle would be crappy and just on the verge of stalling.
Why did my RPM's climb? I almost wanted to drive it around the block and see how it ran.
Is this good, bad or normal? ::
Thanks Greg.
Thanks Greg.
