Need some advice. I have a 1966 289 V8 4-barrel. The engine hadn’t been turned on in 20 years. Among other parts that do not affect the engine turning on, I changed the:
• Intake manifold
• Fuel pump
• Starter
• Alternator
• Distributor
• Ignition coil
• Ignition relay
• Summit carburetor
• Spark plugs
• Spark plug wires
•Battery
• Electrical harness to starter/ignition components
The engine just turns and turns via the starter as I hold the key, but it doesn’t run.
Any advice?
• Intake manifold
• Fuel pump
• Starter
• Alternator
• Distributor
• Ignition coil
• Ignition relay
• Summit carburetor
• Spark plugs
• Spark plug wires
•Battery
Any advice?
