My 65 currently has a 6-bolt 289 that was rebuilt in 1990 by some small shop (long before I bought the car). A few details about the motor... The heads are 289 heads that the PO said he ported before installing. I'm not sure if they have the thermactor bump... any way to check on that without pulling the heads? The car also has a Performer 289 intake and Edelbrock 600cfm carb. The carb seems like too much... I've spent some time tuning it to fix a surging issue but it still seems like it gets pretty boggy. Over the winter I had the rear main seal replaced. While the pan was off, we looked at the bottom of the motor. My buddy said he thinks the motor is in great shape and he wouldn't hesitate to put heads/cam in the motor if I want more power... which I do. I'm tired of joking around that any SUV can beat my old Mustang... but mostly it's true. Oh yeah, and once lockdown orders are removed, I plan to install headers and a fresh dual exhaust. The current 2" dual exhaust is leaking quite a bit both at the header and at a few other spots.
I'm trying to think through the various engine options for my car... I know there are a million. I really don't want to spend a ton of money right now due to the economy... but I also only like to spend money once. If the best choice is to put in a new motor, then I'll just live with the existing setup until I save up enough. Here are the options that I see so far:
1) Use most of the existing engine but still increase power. Target: 300hp. The existing heads were ported by the PO... keep them on the car. Install a new cam. I don't have a tach in the car yet, but based on the MPH and using a chart I created it seems like the car runs out of steam above 4500rpm. I'd like to spin the motor up to 5500 rpm at least... maybe more if I think I can trust the bottom end. The thing I like about this option is that it seems very cheap in the short term. My hope is that I could do this option for ~$1000. One concern I have is that I know nothing about the pistons... no idea if there is the space to go with a cam with more lift, which seems essential to hit higher hp number with this build. I wish old images still showed up... was really curious of the dyno chart from @22GT from a similar build on this thread.
Cam, timing chain, pushrods, valve springs, etc: ~$500
Roller rockers: $300
Tap heads for screw in studs: $200 (?)
2) Buy AFR 165 heads, a new cam, better intake, carb. Target: 380hp. Sort of costly... seems like around $3000. Quite a lot cheaper than a new blueprint engine, but worried that my existing motor might not take this much power. Also worried about valve/piston interference,
3) Buy a blueprint engines 347 long block for $4800 rated for 415hp/415lb-ft. I'll need intake/carb/distributor of course. Would need to figure out what parts I need to change to convert from the current 6-bolt block over to a roller block. I do see that this motor is 28oz externally balanced, so possibly I could keep the brand new flywheel that was just installed during the T5 conversion. Lots of upsides to this motor... forged pistons, roller cam, aluminum heads. The biggest downside I see is that I would need to store my current 289 somewhere in my garage... and I really don't have the space. I'm also hopeful this motor would last a lot longer than options #1 and #2 since this would be a fresh engine.
Thoughts and opinions are very welcome! I really want power and I am not quite sure which route is best!
Thanks!
Rob
Thanks!
Rob
