Assemble the whole thing and spray it blue, or paint the individual parts (block, heads, valve covers, pan, etc.) before assembly?
I like the idea of individually painted parts with the gasket edges unpainted, but I've seen both ways. Shooting it after assembly will be faster and easier. Not concours, so I don't really care much how the factory did it. Any advantages or disadvantages to one way or the other that I'm not thinking of?
Ford painted it after assembly. That is the most correct looking.
I painted disassembled (block, heads, timing chain cover), so that if I ever had to take it apart, I would have less risk of paint chipping/peeling when the parts separated. Not the concours way, but I was happy with how it came out.
760322
Reactions: Blood-J
I painted mine just like Ford did.
The hardest part is making sure that the engine is absolutely spotless.
I used corks to plug the spark plug holes and plastic plugs that I had lying around to plug the other holes.
Use the POR engine enamel, and you'll be pretty close to the shade that Ford used.
Whats your goal? A work of art or a oem looking engine?
I paint the manifold and WP but leave the fuel pump bare. It needs some touchup now and then, thats why I use rattlecan.
I prefer the engine clean, oil and grease free and functional.
I've found engines painted after assembly stayed a little cleaner. The edges of the gaskets painted, sealed in oil that otherwise wicked out. Especially true on cork gaskets.
