Gonna try to keep this shorts as possible and explain it was well as possible.
At low rpm's the car sounds ok however for example if I'm in 2nd gear and step on the gas usually the car has good pick up(usually can go up to about 40mph in 2nd)... but now it starts to pick up but when I hit probably around 30mph the engine goes crazy. I say it spudders(not sure if that would be the right "term") Try to explain it as well as I can here. What it does is it seems to rev, then cut out and rev again but really really quickcly. Almost as if I was giving it really really fast shots of gas. Almost as when you hit a revlimiter.
Any thoughts or suggestions?
(I know this is vague, but I hope someone can help)
Thanks in advance.
I think(and hope) I know what it might be. I was talking with one of my buddies and he said that I should check my distributor and wire...just then I rememberd taking off one of the park plug wires earlier that day to get to something and I know I put it back...but the question is did I put it back correctly. I cain't check right now cause i'm at work, but I will as soon as I get home.
Keep our fingers crossed?!?!
