You pre-lube it like anything else. I use a broken distributor with no geat & a 1/2 hp reversable drill. Adjust the valves with a feeler guage to the specs the cam card gives. If you don't have it, start at .025. Breaking in a flat tappet depends on hydraulic or solid(as does the adjustment). Hydraulic cams break in the same as a solid but most solids run a high spring pressure that requires 1 hour on outer springs only. My main thing to do is break in the cam, I use solid cams mostly, tune it a little, & go drag racing! I never have engine failures or sealing problems. If the engine is new almost all reangs "seat" immediately, if it's slightly used, they already are. If your FE is a hydraulic I'll assume it's non-adjustable, if it is adjustable, run the oil pressure up then tighten the adjuster down while turning the push rod, take out all the slop but the push rod must turn! Good luck...
