Hi,
Post the engine/trans combo so we can understand your situation better.
Generally, unless you have a fairly radical racing engine, you should be able to idle the engine at 750-800 rpm no problem...maybe 700 in gear with a C4...
The engine in my race car, for example, idles at around 950 rpm in neutral and makes nearly twice the HP of a stocker....
The number your husband read may have been for the stock emissions carb which had a idle cutoff solenoid which closed the throttle when you shut off the engine...
Please see this
thread for some more info on running on and the causes...
Good luck!
Pat
