Hello all
Recently put Edelbrock 650cfm AVS2 thunder series carb on, lot's of projects were being done on the car & hadn't started it in quite awhile. Now when I try & start her the engine is running crazy fast, like the gas pedal is stomped to the floor fast, way to fast for cold engine, afraid it will tear something up. I've adjusted screw on fast idle cam, adjusted choke back some, tried unplugging vacuum advance, I don't believe in have any massive vacuum leaks. I've even thought for some Reas maybe the ignition advance timing might be off & have tweaked the distributor slightly with no difference....I'm learning as I go with this car, I'm not a mechanical expert by any means. Any thoughts? I just want to get it to idle safely
