My '65 289 has been running great! Now the engine surges, esp. at idle. So much so that it will actually stall the car. Recently replaced the fuel pump w/ a new Carter one because it was doing the same thing only to a lesser degree. I have the idle set up to keep it going, but what is up? Need help!
Thx, diArdi
Have you checked the float level of the carb? If the float level is too high, it can cause a surge at idle when the bowl fills up.
Yes, the Carter fuel pump has a fuel filter canister and like I said, I just changed it. Hmmm, how would I go about checking for too lean?
Thx
If the surge started suddenly after the carb was working ok, then I would guess it's more likely that some crud/dirt could be the cause. Some little grain of gunk broke lose and is interferring with fuel flow/delivery.
What kind of carb?
I'm not that familiar with stock Ford 2100/4100. In a Holley you would want to check the needle/seat and the bowls for bits of dirt. Edelbrock would need the top pulled off to check the bowls and the jets.
Maybe time for a re-build on your carb. ;)
Check for a vacuum leak.. could cause a surge by leaning out the mixture, make sure you check the throttle shafts for play and leakage also.. Good luck
