I'm getting ready to swap from a 6cyl. to a 289 in my 65 coupe, am i wrong to think that its a easy swap,having to change basically the motor mounts,radiator,and coil springs. Hopefully these are the only major items. If anyone has any more info.that could help me I would sure apreciate it.
Along with the springs (front) you sould also do spindles and steering linkage (centerlink, tie rods, pitman, idler arm). A V8 rear end and driveshaft, and you will also have to re-route the fuel line. Good luck, it isn't "that" bad.
To add to above, throttle linkage, motor support brackets, bell housing, flexplate, torque converter, starter, pulleys, brackets, etc..
Please, do change the spindle. Having seen a snapped one, I can only stress this issue.
