In the box of old spares dad gave me... i found "this" (see pix).
I assume it is the original engine tag (original engine was rebuilt and re-installed).
Where does it go? I want to put it back on.
THX!
Tool Wood Hand tool Font Auto part
IIRC a 390 engine tag goes under an intake bolt near front of engine. not sure if left side or right. or either.
My 390 engine tag is driver side up front, think 2nd bolt. That's normally where the coil is but since I have tri-power setup, my coil moved to front of heads.
Thanks!
I have the same one. found it under the coil bolt ages ago
Like other FE engines built at the same plant that production year. It was attached using the same bolt that attaches the coil to the intake
