I have a 302 with 351w heads, roller rockers, Mallory Pro Master coil, Unilite 9000 distributor, and a Edelbrock 600 carb. My trouble started when the engine would just suddenly die with no warning after running awhile. I've replaced the fuel line and filter. I installed the new Edelbrock carb thinking the old Holly had seen its better days. I can see fuel through the clear filter and watch the carb squirt fuel in the bores. Still no luck. I replaced the spark plugs and set to .35 and replaced the old Mallory coil with a new one. I even checked the valve lash as a last resort. Occasionally it will fire up like today and run for a minute and die before I can do anything. I've tried adjusting the timing while someone else is cranking too. I have only the spark plug wires and distributor left to replace. Any ideas because this is becoming an annoying and expensive problem. Thanks
Man who run in front of car get TIRED. Man who run in behind car get EXHAUSTED.
