Engine?
922 3
Picked up a 65 Mustang parts car with what I think is 302
motor. The only numbers I can find on the block are just above the oil pan on the
bottom right side at the back: 27 E7TE CA S
Can anyone tell me what motor this is? I did see the letters
XX cast in the lifter valley. Thanks,CDC
Looks (from the numbers provided) to be a 87-8 five liter. E7 would decode to 87
Sorry don't have any books to decode (exactly) something that new
Jeff Speegle
MCA Shelby Gold Card
Mustang & Shelby research, documentation, and help.
Where sharing with one .. means sharing with all
Looks like it may be a '87 roller cam block! If it came out of a Mustang, it'll have fordged pistons and a decent street cam. If it's not a Mustang, It'll have flat top cast pistons with no valve reliefs and a really mild cam, it'll still be a roller block though if it has a flat tappet cam. I'm not exactly sure when they switch to roller cams on everything. Not all roller cams are the same. If you want to use it, ( not a bad idea ) you'll have to do something about the different engine balance. Either get the conversion damper and flywheel, or use a earlier 28.8 oz. 302 crank and have the ring ground off the rear main journal. Good luck.
Tom
You can do anything you want to......ONCE!
aka "my 66 coupe"
http://albums.photopoint.com/j/View?u=1575517&a=11977890&p=44194856.jpg
Hale Boppe comet shot off my roof. See you can use 100 iso at night with no flash!
