1 - 10 of 10 Posts
Hi,
My 8000k tach seems to be jumpy as I accelerate. It is fine on start up and at low speed but as I step on it and it begins to reach 3-3.5k it begins to become jumpy...and eratic and seems to stop at the 4-5k mark and will not go above this.
Any suggestions on causes and fixes
Had a similar issue recently - my coil was going bad, causing weird un-explainable jumpy issues and misreadings with the tach. Then one day, the coil just died. Replaced the coil and now the tach is just fine. Could be a similar issue with yours. Good luck!
The signal for the pertonix is to high for the tach input. I added a 47k 1/2W resistor in series. Between the coil and the tach. This fixed the issue.
On my Dads 450sl, that we converted to Pertronix, we ended up using a 8.2K resistor.
So the absolute value may depend on the individual tach.
You could buy a 50K pot from Frys or Radio Shack, connect it in line (center tap to out side) turn the pot till the tach works correctly. Disconnect the wires and measure the pot. Then add the fixed value in line.
Hope this helps
Gary
Hope this helps
Gary
Does using an inline potentiometer work on any tach? Just hook it inline on the coil feed and adjust it until the tach is stable?
My tach is stable at lower RPM but bounces a bit above 3500. I'm figuring it's just a worn-out tach but I'd try this.
Banned
Hope this helps
Gary
I've got a Pertronix coil and it works fine with my tach. I know this to be true because I told the guys who chassis dynoed the car to check the tach to make sure it was correct.
There is one other possibility, just to possibly complete the tach diagnosis picture. Original D'arsenval tach meters are by nature easily damaged and definitely do not like being contaminated by any metal shavings inside the meter. I had this happen with my 6K tach years ago. Don't ask me where the shavings came from, but somehow they got into the tach. They made the needle hesitate above 2k rpm at several places and then actually get stuck partway around the dial. If I tapped the gauge it "released" the needle. Useless for driving!
Hopefully the OP's case is related to the Pertronix and the signal being properly calibrated when it reaches the tach. Otherwise it needs rebuilt. Tachman is a good rebuilder, there are others out there.
1 - 10 of 10 Posts
