1 - 9 of 9 Posts
While crusing last night, my tack needle stuck at 4K. The damn thing won't move.
Hold old is the tach?
I had a problem with my an Autometer tach of mine, sent it back to them and they replaced it free of charge. IIRC, the warranty period was within a year
Moderatly Old Fart
AutoMeter is great! I had a bulb burn out and they sent a replacement in the mail.
When I was hooking up a tach in my pick up the instructions said to hook the wire to the coil. Which one? There are 4! A quick call to technical support took care of in a hurry.
H2O temp gauge has problems sticking sporadically. Purchased new, installed 3 mos ago. Worked fine for a couple weeks. May be a loose connection/wire that I haven't checked out yet, so haven't contacted autometer.
I bought a JME bezel with Autometer gauges through a VMF group purchase about 5-6 years ago.
Everything worked fine until last night. It is probably out of warranty, unless it is a lifetime warranty.
Autometer has a repair shop and charge a flat fee, depending on which gauge.
My tach just shelled out also. Need to pull it and send it in.
My Auto meter tach does not return to zero when off! Too much trouble to take it out cause it is built into cluster.
Try turning the key to accessory after you turn the car off and then back to off and see if that returns it to zero. That's what I have to do on mine.
Discussion Starter #9
Thanks, I'll try that.
1 - 9 of 9 Posts
