Can anyone tell me what a "safe" clearance should be between the exhaust headers and the inner shock tower?
I put on new headers for my 5.0 transplant and I am a bit close. Less than one inch on either side. Is that safe? Any suggestions? THanks.
Colt
http://www.geocities.com/cboomg/index.html
"No Cure for Mustang Fever"
"If I had known that getting married would slow down my Mustang restoration, I might have waited - getting married that is."
I'm running about a 1/4 inch on the driver side with Hedman's. I feel lucky to have that much. No problems. I've seen some with only 1/8.
65 FB "J" 302 lots of mods. 94 GT K&N only.
http://albums.photopoint.com/j/view?u=1590489&a=12113030&p=43871256&Sequence=7&res=high.jpg
You dont have any problems with the engine torqueing over and hitting the inner shock tower? Thats my biggest concern. I also worry about the heat that is coming off the exhaust peeling the paint off the same area.
Thanks for your responce.
Colt
No problems at all. The headers are ceramic coated, but even before, I never a paint problem.
I've only got about 1/4" between the header tube and the passenger shock tower (Tri-Y). No problem
DanM
66 Coupe, check her out at http://www.66CoupeNW.stangnet.com
"Imagination is more important than knowledge. It is a miracle that curiosity survives formal education" - Albert Einstein
I have about an inch or so, you're fine... Right now I'm more concerned w/ ground clearance, hehe, about 3"; SCRAAAAPE!
-Jason
'72 Mach 1 || '90 Talon TSi AWD
http://nosaj122081.tripod.com/parade3.jpg
"Thats not a leak, my car's marking its territory!"
"If you've done it, it ain't braggin'." -Roy Rogers
3"? thats a bit close. I have a bit more than that even with the deep pan I am using. ;)
I have less than 1/2 " clearance on both sides. From what you guys have said, that sounds like it should be OK. Thanks!
Colt
