I believe is means "IMproved COmbustion". Usually had a belt-driven air pump that put air in the exhaust manifold to allow continued combustion in the exhaust and reduce emissions.
Nope. You're describing the Thermactor system with its belt-driven pump.
IMCO deals with specific lean carburetor settings and revised timing via the vacuum canister, etc. That's the V8 setup at least.
Yep. Basically the IMCO system was very careful matching and tuning of such components as the carburetor and distributor.
Per the shop manual (page 8-34 if anyone is interested):
IMCO
The IMCO exhaust emission con-
trol system controls engine combus
tion at a level to reduce contam
inants normally emitted through the
exhaust system. This is achieved by
using a specially-calibrated carbure
tor and distributor in conjunction with
revised valve timing events.
