I want to do a front disc brake conversion. Ideally, I would like to use period correct factory disc brakes. I've found a 68 Cougar donor car with factory disc brakes. Can the entire front brake assembly be swapped to my 68 Mustang? Looking at using the calipers, rotors, spindles etc. Also, did Ford use the same calipers on the 68 Galaxy as the 68 Mustang? I'm getting a 390fe out of the Galaxy and it also has front disc brakes. Thanks.
