Lining up is one thing, quantity is another. For what he is doing he needs 2 for the alternator, one for AC and one for PS. All need to run off the crank, thus a 4 belt crank pulley needed. The two belt alternator is really the odd ball thing here.One more question I might add, can you send pictures of how your accessories and pulley are lined up? That can give people a clearer view of how they suggest routing your belts.
I believe the picture you showed has the belt layed out differently. I see the a/c compressor going to the crankshaft pulley and to the water pump. The belt near the alternator appears to go to the water pump and down to the crankshaft pulley and back.Potentially a long belt could be used to go from crank to alternator to AC, but engagement on crank pulley would be limited as it would only engage 1/4 the circumference of the pulley or so and thus it might be subject to slip, especially when AC engaged. Given the price of a belt, it may be worth a try. It would allow a 3 groove crank pulley. Equal belt speed for the alternator should be okay as long as the two grooves on the crank pulley are the same diameter.
Absolutely the picture shows a different routing. The "potential" ALTERNATIVE routing I outlined in red is NOT the usual routing, but it extends the AC belt to also pick up the alternator. The picture as taken only has 1 belt going to the alternator. The OP needs two to avoid belt squeal with a high output 3g alternator. It is a compromise that may or may not work long term due to differential belt wear. Furthermore, it does not have as much belt in contact with the crank pulley thus it could slip. It's probably a $20-25 risk to try it based on the cost of a long belt. The OP could just jump into a $720 CVF or March serpentine set of pulleys and be done. By nature I am cheap and I like to experiment. $25 gamble or $700+ sure thing? We all make choices.I believe the picture you showed has the belt layed out differently. I see the a/c compressor going to the crankshaft pulley and to the water pump. The belt near the alternator appears to go to the water pump and down to the crankshaft pulley and back.
