I just bought a 3 row radiator, thermostat & fan shroud for my 66 coupe ,it has a 289 2v no AC. Everything went easy until it came to the shroud brackets ! The brakets & shroud are from Mustangs unlimited. According to the packaging they are the right brackets, they just don't seem to fit right. No matter which way I try, they don't all line up right. Any suggestions or pictures would be appriciated ! Thanks
This is a little hard to describe, so bear with me. Both brackets on one side will face up and on the other side will face down. Place the shroud against the radiator and you should see what I mean. It can be a juggling act to get everything to line up.
I e-mailed you pictures of how the bracket go on the car.
had the same problem, you just have to play with things until they line up perfectly
