1 - 10 of 10 Posts
Nailbender and Kelly got me onto buying this Northern radiator and so far so good I hope but now I am in need of a shorter fan spacer,the one I have is 3 1/8 inches overall and I think I need 1/4 to a 1/2 inch shorter.
763911
763912
I also had to massage the crossmember so the rad could fit without rubbing. If anyone has a spacer that would be great.
Check you local parts store . Hayden makes them in several lengths
Nailbender and Kelly got me onto buying this Northern radiator and so far so good I hope but now I am in need of a shorter fan spacer,the one I have is 3 1/8 inches overall and I think I need 1/4 to a 1/2 inch shorter. View attachment 763911 View attachment 763912
Oreily's has them in any size you want
Always prefer a Ford part first but as a last resort.....
When you get your shorter spacer be sure to double check the length of the bolts. If they are too long they will go all the way through the hub and bottom out on the body of the water pump and "jack" the hub off of the shaft of the water pump. It happened recently to a member.
1965 Mustang Fastback GT350-Tribute Restomod. 2019 Shelby GT350.
I've got an old generic 1.75" aluminum spacer that is a take-off from my '65 Fastback. Probably not your preferred piece, but it may do till you find your prize. It includes Grade-5 bolts. You can have it for the cost of shipping. PM me if interested.
763928
Discussion Starter #8
Already was thinking about that.
I can't figure out how to post pics but I have two that are 2 1/2" and one that is 1 3/4" $25 each plus flat rate shipping.
1 - 10 of 10 Posts
