Vendor
This is our FAQ and tech support thread. Feel free to post up any questions you may have about our product if you don't see it posted below.
Custom IFS wheel fitment info: Track width = 57.5"
'64.5-'66 = 7" wide wheel w/4.75" backspace(dropped spindle)
'67-'70 = 8" wide wheel w/4.75" backspace(dropped spindle)
*NOTE* You can fit another inch on the outside with a stock spindle on any year vehicle.
Torque Arm wheel fitment info: These measurements are based on 56.5" A/F to A/F
'64.5-'66 = 8.5" wide wheel w/5" backspace
'67-'70 = 9.5" wide wheel w/5" backspace
Power Rack & pinion steering column input shaft = 3/4" x 36 spline
Manual Rack & pinion steering column input shaft = 9/16" x 26 spline
Power rack fittings = 5/8"-18 Return & 9/16"-18 Pressure
Replacement parts:
Rotors, Seals & Bearings = '75-'80 Granada
Upper Ball Joints = Moog Part# K772(screw in)
Lower Ball Joints = Moog Part# K719(screw in)
Brake pads for use with GM calipers = 78-85 GM
Brake pads for use with 4 piston Wilwood = 150-8850K(BP10)
Upper Control Arm Bushings = Energy Suspension Part# 2652.01(4 needed)
Lower Control Arm Bushings = Energy Suspension Part# 2618.06(8 needed)
Anti-Sway Bar bushings(1") = Energy Suspension 5010G(2 needed)
Anti-sway bar bushings(1.125") = Energy Suspension 5012G(2 needed)
Anti-sway bar bushings(1.250") = Energy Suspension 5013G(2 needed)
Engine Mount Urethane = Energy Suspension Part# 2618.06(4 needed)
Rack & Pinion(Manual) = '74-'78 Mustang
Rack & Pinion(Power) = '86-'89 T-Bird(2.5 turns lock to lock)'80-'85 T-Bird(3 turns)
Tie Rod Ends = Part# 10162 or 8024170 depending on where you're buying from
Rear suspension Link bar replacement bushings = Energy Suspension Part# 2652.01(8 needed)​
Torque Arm front attachment bushing replacement = Energy Suspension Part# 2652.01(2 needed)
Installation Manuals:
'64.5-'70 Mustang & '67-'68 Cougar Custom Independent Front Suspension Installation Manual
http://www.totalcostinvolved.com/assets/pdf/64-70_Ford_Mustang_Front_End_Ver3.pdf
'64.5-'70 Mustang & '67-'68 Cougar Rear Torque Arm Suspension Installation Manual
http://www.totalcostinvolved.com/assets/pdf/64-70%20Mustang_Torque_Arm_Rev02.pdf
-J
