As others have mentioned this is a GMB case with the FlowKooler bearing and impeller. Overall, it looks like I would expect for a new part. The pulley spins with a bit of resistance but no grinding and it doesn't wobble as others have reported. It doesn't spin as freely as the old one but I'm hoping the difference is wear and tear. Here's a picture for reference.
Aligning schedules to get time to work on the Mustang proved a bit difficult but finally got to swapping out the water pump. Here's Emily breaking the old one loose.
Upon removal of the old water pump, I was saddened to see the driver's side water passage completely plugged. I'm not sure if you can tell from the photo but it's plugged with a mixture of something like plaster, rust and sawdust... Yuck!
With thoughts of the driver's side head not getting coolant, we dug the gunk out only to find that there doesn't appear to be an actual water passage. Rather it's blocked off from the original casting. Is that possible?
I poked around in there with a screwdriver and it's solid and 'klinks' like tapping on metal. Well after pondering the possibility of alternate water routing and searching for coolant flow diagrams online, I couldn't find anything that suggests this should be blocked. So I poked harder with the
screw driver and finally it gave way. The metal is very thin and now you can see the hole I put in it.
So now my question to you experienced guys... is this supposed to be open for coolant flow? Do I need to plug it back up? Has it been starving the drivers side of coolant and I likely have other issues? Remember, I've only driven the car a limited amount and in cool weather but didn't experience overheating allthough I'm not sure if the temperature gauge would have even indicated a overheating problem if there was a lack of coolant flow.
PROJECT CREEP ALERT.Not what you want to hear ,But you should consider going a little deeper. At least remove the timing cover and scope things out from there probably needs a timing chain anyway. If things are still plugged and full of rust you may be into a rebuild.You'll want this http://forum.ellum.ch/Ranger/How To Rebuild Your Small-Block Ford.pdf
Yea... that engine needs to be pulled apart and hot tanked to get rid of all that mineral build-up. If not, you are just asking for overheating issues.
At a min, I would pop all the freeze plugs and rinse everything out and clean the block through the freeze plugs (with water hose, screwdriver, etc). This is best done with ththe engine on a engine stand.
I did this on my engine (it was out when I bought the car) and was able to clean out a bunch of rust from 20 years of sitting (as well as what looked like original casting sand). It really only takes a couple hours to pull the engine if you have the tools/ space. If the engine ran well, a quick cleanup and gasket change could be done over a long weekend. As mentioned, you always run the risk of project creep.
That sort of buildup is common in an engine that old. In the southwest the water has a pretty high mineral content unless you soften it. The car predates using pre mix coolant and could be it's been run a good amount of its life on straight water or not with an optimal water/coolant ratio. If those water pump connections are that damaged there is a good chance some of the water jackets in the block are clogged or near clogged.
Like Roboticservo says best to have the block tanked and measured. Looks like it's never been apart or it was a long, long time ago. You've already got the harness and FI at this point. You could put something more modern it but with FI and some new bits you can still get a fair amount of power from that 289. Enough for a good driver/cruiser.
Were it mine I wouldn't hang a bunch of new accessories on it until I knew the block had good flow and measured in spec. Figure $100 or so for the tank, cam bearings and freeze plugs. Then you'll want to look at the bearings and rings. You could do a leak down and compression test to get an idea on the rings but at this age you may want to do bearings and rings. That may require a hone, maybe a bore and some crank work. Realistically you could have $700-800 into a short block rebuild depending on the machine work.
If you go with a modern resto mod you'll be a few grand into motor and trans easy. Plus the fab of fitting it. If you go with an unknown quantity of a used late model engine you may need to have the engine rebuilt anyway though you could go someplace like LKQ and get a pretty good late model salvage with a bit of a warranty. But it won't be a drop in either.
Sorry, but don't despair to much putting a SBF together is almost like therapy, unless your that really unlucky guy that has had the worst luck with his 331
The water pump picks up the coolant from the radiator through the lower hose and pumps it into both sides of the block through those two holes. From there it flows through the block to the rear and then up to the heads through the holes in the head gaskets. The forward ends of the head gaskets do not have holes to allow coolant flow thereby forcing the coolant to go to the rear of the block. (That's why the head gaskets are marked FRONT). There are some small holes in the head gaskets between the front and rear to allow a limited amount of coolant to flow from the block into the head and to allow bubbles to escape.
The coolant flows back forward through the head and then enters the intake manifold at the forward end where each head opens into a common plenum in the manifold behind the thermostat. Of course from there it flows through the upper hose back to the radiator.
Before you go all the way to tearing the engine down you may want to remove the timing cover and clean those 2 holes out and then reassemble it. Then do a "citric acid flush" and see if that cleans anything out. Maybe a couple of flushes and rinses for good luck.
Once you've done that and confirmed that the engine does not overheat you can proceed to add your EFI, etc.
The citric acid flush works well. A word of caution though. The flush is going to bust debris in all parts of the cooling system. I'd watch around the freeze plugs, radiator and heater core. If the water jackets in the block are that clogged it's a good chance that when those deposits are loosened he could get some leaks in other parts of the system. That's not the fault of the acid wash but rather an indication those parts were done and needed replacement. If the heater core lets go the interior could be in for a world of hurt or perhaps worse a slow leak you don't notice until the carpet has been soaked and mildewed. Being in the PNW (I lived in Seattle for 15 years) they'll need the heater and particularly the defroster for a good part of the year. Might be a good time to replace or rebuild the heater system anyway.
Yes, that is the reason why you need to use demineralized water in your cooling system. That gunk is in every water passage of that engine. Normal coolant changes and flushed will keep that from reoccurring in the future (after a rebuild).
If the engine was running and the build-up wasn't that bad, you probably could have gotten away with doing a series of strong flushes. But from what I see there, I would hot tank the engine and have the shop check the measurements while installing new cam bearings.
Evaporust/Thermocure will eat that stuff away and turn it to a powder like that can be carried away, it has to be immersed completely though.
I have used the Evaporst many times and have but 1 worry. It cleans amazingly well but anything treated will go from beautiful to re-rusted crap rather quickly if the metal is not protected somehow. I fear the rust returns with a vengeance where it cant be seen.
You can take your parts out of the evaporust and not rinse them, for a rust-protective coating. Sticky, but it will keep off the flash rust for a long while. Talks about this on the back of the jug, or at least it used to.
evaporust is my go-to for restoring delicate parts that can't go through the blaster or too small to set up the electrolysis tank for.
For this application I think a big tub of CLR would do him better. The main component in that crud would most likely be calcium. I don't think evaporust works on calcium, but CLR or a mild mix of Phosphoric acid would do both the calcium and rust.
But for this one, I would drop that cruddy sucker off at the machine shop and tell them to:
hot-tank
hone cylinders (bore if needed)
hone crank bearings (bore if needed)
replace cam bearings
measure and recommend new crank bearings
Check the valve seats and regrind if needed
Replace valve guides and machine for posi-seals
Check the crank if you are reusing
Press pins for pistons and arms
Measure and recommend bearings for connecting rods
Only thing I *might* do before dropping it off at the shop, would be to port the heads to match your headers and improve the flow. Also check to see if you need any porting between your head and intake. Better to do all that grinding before you get everything washed out real well.
Putting together a 260-351w is pretty easy. Basic hand tools and a decent torque wrench is all you really need. I highly recommend replacing the head bolts with studs. ARP makes a kit for your engine that has all new fasteners .
I know all the engine work sounds like alot, but this is pretty basic stuff for any machine shop. You should be able to walk out the door having spent less than 600 or so.
It looks like other hard water issues in the desert. In AZ they're in the Sonora, I'm in the Mojave. Same issue both places. Caliche. It's serious calcium with some lime. In the ground it basically turns to cement. It builds in the water from run off, aquifers and the like. Unless you truck or pipe water in any naturally available southwest desert water is going to have that high a mineral content. We use CLR on some things but if it's a heavy deposit or even regular maintenance on something like a toilet or drain that can take it we use muriatic acid. Some deposits can be so hard CLR doesn't budge it.
... If the heater core lets go the interior could be in for a world of hurt or perhaps worse a slow leak you don't notice until the carpet has been soaked and mildewed. Being in the PNW (I lived in Seattle for 15 years) they'll need the heater and particularly the defroster for a good part of the year. Might be a good time to replace or rebuild the heater system anyway. ...
You are right about the need for the heater/defroster. Luckily the previous owner had just replaced it and it had been doing the slow leak as you describe.
hot-tank
I know all the engine work sounds like alot, but this is pretty basic stuff for any machine shop. You should be able to walk out the door having spent less than 600 or so. ...
You're right, it does sound like a lot... but $600 seems very reasonable for all that; I was thinking much higher. I'll see if a local shop will come close to that price.
You can get an inline filter for your radiator hose to catch anything while you flush the system with whatever solution you choose to go with.
BUT, if you rebuild the engine now it's one major component that you wont need to worry about. And while its out you can much more easily clean up the engine bay.
I got out of the mustang game roughly 10-11 years ago when I moved to FL. I sold my fastback and had a motorcycle and even had an early bronco for a while. I have always been on the look out for another mustang and stumbled upon this rusty 66 coupe that had a boss 302 engine in it. Yes the...
Well, about a month ago I picked up this T code coupe in running(but disassembled) condition for $2500. The body itself is mostly ok...with the exception of a quarter panel patch I dont much care for and rusted floorboards(and presumably a rusted cowl).
I decided to start with the floorboards...
So, as some of you may remember from my previous posts, about a year and a half ago I took a week off work to do a H/C/I (Heads, Cam, and Intake) swap on the 289 in my newly acquired, “fully restored” $38,000 eBay special 1968 Mustang Fastback that I had just purchased from a dirtbag named Bruce...
Finally doing what I've been wanting to do for years.. I started resto-modding my first car..
I've owned the fastback since 1983 and drove it daily in High School. Then I put it up after graduation and got into Custom Mini trucks. I learned a ton of fabrication skills doing them and other...
While my first post on VMF, not new to restorations or builds. In addition to multiple restorations over the years, I’ve also built an FFR Cobra that took 3rd place in the FFR Nationals. But my hope is re-working this car will be much easier...
This time I wanted something fun for the...
