1 - 17 of 17 Posts
I'm doing a t5 conversion in my '65 Mustang and went with the mustang Steve setup. I bought his firewall adjuster, fox booster, pedals with the quadrant, and the reinforcement plate for the firewall where the pedals mount to the firewall.
Everything is hooked up now. While I was adjusting the clutch cable I couldn't help but notice a horrible creaking noise and tons of firewall flex. See video below (copy and paste into the address bar if clicking the link doesn't work)
https://1drv.ms/v/s!Aq0rbhaiSGJ0gZEYbT8Nu-l9nenP4Q
Is this anything I should be concerned about? I'm worried that the firewall will crack over time. To be honest I'm quite upset that I invested as much as I did into this setup only to see so much flex in the firewall.
I'm not sure what to do right now and am looking for options. I could leave it as is and stop worrying about it. If I convert to a hydraulic clutch setup then I'll have the big hole in the firewall from the clutch adjuster and I'll need to convert to manual brakes because the hydraulic clutch setup doesn't fit with the booster there. If I convert to manual brakes I will then have the problem of my firewall being modified for the bolt pattern of the fox booster. I'd prefer not to run manual brakes if I can help it because I'm running Cobra disc brakes on all four corners.
Any thoughts or ideas on where I should go from here?
I don't think it'll clear the booster by the looks of it, but they might offer a different one. I actually added a flat plate behind mine too, came with the Ron Morris kit, lengthened the pushrod the same, and it works fine. Your video won't open, so not sure just how bad yours really is, but mine barely moves at all.
Have you contacted Mustang Steve about your concerns? Many, many of us have his products including the cable clutch conversion kit. Steve will surely be available to assist you. Hopefully, it is nothing that can't be resolved easily and inexpensively.
I've read a few threads about firewall flex.
Is this an issue with hydraulic clutches too, or is it more of a cable clutch issue?
One of my earliest memories about driving an early 'Stang is how I could feel in my feet the floor and lower firewall flex when hitting standing water with any speed:) Not rotten just the way it was.
If you strip it apart I wonder if a doubling of the skin and panel bond or spot weld might be good?:shrug:
I have a hydraulic clutch and feel some flex as well.
Discussion Starter #10
I spoke to Mustang Steve and he advised that this is all normal. He mentioned even the original manual transmission mustangs with the linkage have firewall flex. Seems like this is nothing I should really worry about too much.
WHen I put my hydraulic master in, I welded a small 1/8" plate with some gusseting (with two nuts welded to it) to the clutch/brake pedal housing so the master bolts directly to the housing sandwiching the firewall and therefore eliminating all flex. I didn't like the flex. I tend to over-engineer things as these types of projects are part of what I enjoy about this hobby, (winters are long here). The design is such that all the stresses never leave the housing...
How big was the 1/8" plate? Do you have any photos of it, I have some 1/8" plate and a brand new throatless shear I want to use.
Boy if you lived near me, this would cost you a beer - took a while to get decent shots... The gussetting looks like 1/8" but the plate looks thinner. I did this years ago so frankly I'm just happy I remembered I did it...
Cheers,
M
Cheers,
M
Thanks, I owe you an adult beverage
I agree that even new, there was a lot of firewall flex on most of them. I had one that had very solid firewall, and two speed wipers. Turn those wipers on high and you could feel it in your feet every time those wipers whipped past.
If it's still flexing make a bracket and attach it to one of the master cylinder bolts and bolt the other end to the shock tower. That should really help!
1 - 17 of 17 Posts
