What do you recommend as a sealant on the firewall electrical penetrations.
I have grommets installed but there is still daylight and I'd like to seal them up either from inside under the dash or from the outside.
The wiring harnesses are all aftermarket (AAW, Holly EFI and Old Air Products AC)
3M strip caulk
Reactions: erials and rhutt
Or some 3M Bedding and Glazing Compound for the OE look and feel haha
Post a couple of pictures as it will make clear what you need to seal. If you have some form of wire loom or electrical tape is around the individual wires, the suggestions above will work fine. Otherwise you have an opportunity for moisture to enter between wires. To more effectively seal off the pass through is such a case, maybe some black silicone gasket maker squeezed between the wires from behind the dash would help in blocking moisture from finding its way in. The standard silicone gasket maker can be removed down the road should you ever need to remove the wiring.
I seal off all those types of areas with strip caulk.
I have both taped looms (sometimes more than one per grommet) and individual wires.
I thing the strip caulk will work on the taped pass through's and I like the idea of black silicone gasket maker for the pass through with individual wires or multi taped looms.
