1968 was the first year for a Mustang option, and 1969 they became standard for passenger cars, 1973 for pickups I believe.
Mostly correct in that for MODEL YR 68, Ford would build them all to meet the requirement. But anything built in 67 would not need to have the 68 requirement.Title 49 of the United States Code, Chapter 301, Motor Safety Standard, which took effect on January 1, 1968, that required all vehicles (except buses) to be fitted with seat belts in all designated seating positions.
although someone will contradict, every 1968 MODEL Mustang I have seen has had shoulder belts,
A car built December 12, 1967, if sold right away, would have slipped under the requirement, but if it sat on the dealers lot until 2 Jan, it would have been required.
Same requirement for side lights.
There are retrofit kits to put shoulder belts in 65 - 67 cars
Yes, they don't mount them where they do by accident.I'll say this as I've said in nearly every seat belt thread. Adding seat belts without proper engineering can turn a fender bender into a spinal injury. Your seats are NOT designed for it. The placement is critical as well as the strength of the anchors. It is NOT always a case of "better than nothing"
I totally hear that. Even where the pressure points are on your body is critical. I just wanted to know what came with them. So, I could reasonably get a 68 with stock lap and shoulder belts. If I wanted to retrofit I’d certainly look into it being done “right”. Thanks for the warning, of course.I'll say this as I've said in nearly every seat belt thread. Adding seat belts without proper engineering can turn a fender bender into a spinal injury. Your seats are NOT designed for it. The placement is critical as well as the strength of the anchors. It is NOT always a case of "better than nothing"
For Mustangs, the answer is the 1967 model year, as just an option. Front seats only, and the shoulder belts only came in black. I've seen a blue interior car with all black belts, and a blue interior car with blue lap belts and black shoulder belt.A simple question: what year did shoulder belts become available, even as just an option?
