·So I ran a couple of water tests this weekend and found all of the leaks, or at least the first three there may be more after I fix these.
The first was in the windshield at the lower passenger side. I reasealed the window with clear silicon and that stopped the window leak till I can get a new window and seal. I need one anyway.
The other two leaks are in both cowl vents going into the heat ducts. I poured water in the cowl and had spill on both sides. I oredered a cowl vent seal kit that contains two rubber gaskets for the vent tops and silicon.
My qoestion is this. How can I get in to the vents to install these seals. I am driving this car daily. Has anyone installed this type if kit before?
Suggestions would be appreciated.
I know the best way to fix this is to cut out the panels and replace them, but I cannot do this right now. And I want to try and fix the vents before I seal up the entire cowl. If I could avoid that it would look and function better to keep the cowl open.
Jimbo65
65 I6 200 Coupe (Daily Driver)
Jimbo65
