yes the cam is too small, use a high energy 268h or the summit hyd cam with 218 deg's duration and 480 lift.
Scrap the 351W idea.Ok, going with just the engine.. tell me what you would reccomend for my application.
DaveSanborn said:Welcome.
Read, read and then read some more. There isn't a question that you may have that has not been asked here before. Learn from the mistakes of all of us... well, not me, but most of these other guys
Anything over 300 HP to the rear wheels is going to get you in trouble in a street car. "Trouble" comes in many forms. Speeding tickets, reckless driving tickets, car in a ditch wrapped around a tree tickets..... These cars are light enough that 300 HP will plant your back firmly in the seatback. As an example.... an OEM "low back" seat back by the looks of the pictures on the cardomain site.... 350 RWHP is a race car. With stock seats and a lap belt? Really? 350 RWHP means you'll need to stop faster/quicker than the OEM brake system ever dreamed of doing. 350 RWHP will twist the unibody frame design of the car without any strengthening. Sub-frame connectors are only a piece of the strengthening puzzle. Adding a passenger side torque box to your "doesn't have one of those" '67 is one area for chassis strengthening improvement.
Think about this for a second....
If you had an unlimited budget to build a 700 HP motor.... would it spin the rear tires faster/longer than a 250 RWHP "budget engine". Yes, it would, but guess what? The object of building a high HP motor is the ability to successfully transfer that power to the ground... to create rapid forward movement/acceleration, not to spin the tires. A kid on a moped could get to the finish line before you if you're still sitting at the starting line with your tires spinning.
To get those tires to stop spinning and "bite" requires money. You could simply slap some slicks on the back and the tires would bite, but then you'd snap your pinion gear. After you invested $2-3k in a new rearend, you'd snap your 1310 series driveshaft u-joints. After you upgraded your driveshaft to a 1330/1350 series unit, you'd likely grenade the tranny.
Do you see how/where this is going?
Building a car that will reliably transfer 300 RWHP to the ground is an "undertaking". Usually one that is not accomplished by a novice in short order.
The first advice I can give you is stop watching "over-haulin' reruns". 99% of those cars are pure junk that are nothing more than a showcase for Chip's one-off wheels that never see a rain drop. Along with "overhaulin'", wipe your arse with the aftermarket car magazines that are written only to support the advertisers within them. Little, if any, real knowledge can be gained from them and the money would be better spent on something softer/more absorbant.
Come here for your education/learning experience. We all live in the real world.
The next piece of advice is to plan on it costing more than you're currently envisioning. Likely, lots more. In the end you'll have a nice car that you'll have likely spent twice as much on as it'll ever be worth.
Wow Dave,Welcome.
Sounds like you're either talking about the outer cowl piece are the torquebox. If you have rust there, you are going to have it in other places. And if you start tearing into this piece, you're going to end up having to replace other rusty metal. Don't ask me how I know that.1 I have found a part i need to replace due to rust, but i do not know what in the world this part is called. Easiest way to describe it is if you look into the cars wheel well with the fender still on, its the panel most twords the rear. If the fender is off, it almost follows the line from the front of the cowl down. It has some kind of rubber material wrapped around the edge of it where it comes into contact with the fender. I dont know how to post pics or i would, but thanks ahead of time for giving it a guess without visual help
