1 - 9 of 9 Posts
Is there a degreaser/cleaner out there that stays where you shoot it (i.e. Scrubbing Bubbles). I have some serious cleaning up to do under the car, especially near the pumpkin. I would like to get it all clean and degreased while still preserving the underlying paint. Ideally, I would spray on some foaming cleaner/degreaser and let it set for a while to really get in there and break up the gunk. Suggestions?
Saw a post here the other day about using some of that foaming oven cleaner. A couple of folks said it worked great for grease and grime.
Note that I've never used this myself. I'd be interested in the results if you try it. Good luck!
For really grimey stuff, I use oven cleaner. You cannot preserve the paint this way. Aluminum will turn grey.
I know it doesn't answer your question, but you might get frustrated take this more brutal approach. It might be quicker to do this and repaint.
Discussion Starter · #4 ·
Yeah, I have read about the Easy-Off approach too...the one thing that scares me about that is the potential damage to anything that isn't metal. Ruining plastic and/or rubber parts is not the objective here. I have some smog parts on the shelf that I can test it on. They need a repaint anyway...I will repost with some pics (before & after stuff) by tomorrow. Thanks for the reply.
You might purchase a small pressure sprayer such as used for weeds and bug control and use some diesel fuel in it to spray the areas you need cleaned. It would probably take a number of applications but the diesel wont harm the paint...
Have you tried the foam type engine degreasers?
It works well on spots with accumulated dirt/grime.
Trick to is to use hot water when rinsing.
Also try using a pressure washer like Simoniz or Karcher.
I have a rear center section out and the pressure washer
with hot water cleaned it well and no grease around.
Discussion Starter · #7 ·
I have used it in the past, and it has a tendancy to etch paint the same way oven cleaner will. It is ready available however considering I have two cans on the shelf as I write this. I will try it along side the Easy-Off and post pics so you guys can be the judges as well. Thanks.
I just recently bought some foaming stuff from A-zone made by Simple Green...wasnt too strong and as long as you use warm water, i think it would work pretty well...it did for me anyways.
-Ryan
I have tried the generic foam stuff. You may as well spray shaving cream on there. I strongly swear by Gunk. Even on undercarriage parts, try it then use a pressure washer. It has worked for me.
1 - 9 of 9 Posts
