1 - 2 of 2 Posts
I just received a Scott Drake Fog Light kit for my 67 coupe. Everything mounted and wired up to the firewall. (pretty simple) My question is, I can't figure where the underdash switch mounts. I also can't for the life of me figure how to do the underdash wiring. Any help is appreciated including diragrams if possible. Thanks alot
The fog light switch mounts to a flat steel bracket (I bet it's not included in the "kit"). This bracket mounts underneath the ignition switch and is held in place by the same screw that holds the ignition switch bracket to the dash.
Since I have not seen the "kit", I cannot tell you how the wiring should route. The basis are: one lead connects to the back of the ignition switch, another other lead connects to the fog light relay, and one lead is grounded.
1 - 2 of 2 Posts
