I have painted all areas before seam sealing. Should I repaint areas that i seal? Prime first or just shoot some more paint on them?
The factory did the seam sealing first, followed by painting the body.
EPOXY PRIME FIRST. Seal the metal as best as you can. Look at the problems in the mustangs where rust starts. Usually under the seam sealer since there was no paint. Over time, it can lift and let moisture in. Epoxy prime, seam seal, prime again with regular primer, then paint.
