1 - 9 of 9 Posts
OK, I have a DSL service. My kids are into on line games. I would like to let them both on at one time , but they need seperate IP addresses. I have a 4 position hub and a wireless network connection.
Is there any way to have seperate IP's without a second provider?
Thanks!!!
You need a cable modem/DSL router. It will dynamically route the traffic using 1 ip address, They are available locally for under $100.00. The hub wont work for this application...
You can get a router that assigns separate IP address. I just got one that does this its Link-Max's LM 341. I just dont know if it will work with wireless.
I do not think a hub will do it. A router connected to your DSL modem should do it. I have a 4 port Linksys router which is assigned the IP address that my cable provider sees. Each computer connected to the router has its own IP address which is assigned by the router.
There may be other complications especially for online game playing. I don't have my documentation for the router here but I remember reading something about different ports needing to be opened or some other computer lingo.
Good luck
Rich, as everyone has suggested, get the cable/DSL router. Then off of one of the ports on the router, attach your wireless hub. Now you can have the best of both....your kids are happy, and if you're lucky, you can be on VMF from the garage/forums/images/icons/smile.gif
BTW - by sure to change the default admin password on the router.....this will help prevent hackers from accessing your network.
Gregg
Discussion Starter · #7 ·
I gotta tell you... this place rocks!!! Thanks you all!! I'm on my way to the 'puter store!!!
Discussion Starter · #8 ·
Gregg, maybe a web cam in the shop where everyone can watch me! Naaa, too much butt crack possibility. /forums/images/icons/smile.gif thanks again.
well, here's the deal: if they are both browsing web pages at one time then that means you probably already have a router.
Many games require seperate IP adresses, this is a common problem, and often times theres nothing you can do about it. You might be able to get by if they arent playing the same game at the same time on some server outside of the network.
best bet is to call up your provider and ask if there is any way you can get a second ip adress. It will probably cost you.
1 - 9 of 9 Posts
