1 - 11 of 11 Posts
Engine
408ci stroker. Forged internals about 13:1 compression. Trick flow twisted wedge heads (with work done) 1.6 roller rockers. Custom single plane intake with nos fogger system (250hp) 1050 Dominator sitting on top. I also have a plate kit that goes with it it should be around 200 250 horse also. MSD billet distributor and MSD coil. It does have a front sump pan on it. I have the engine put on the dyno about a month ago. It made 541hp and 538ftlb naturally aspirated. I have the dyno sheets to go along with the engine.
Transmission
Needle bearing c4 with a stall. Built to withstand a lot of horsepower. I'm not sure the specs on the stall converter I will try to get numbers off of it and look them up.
I'm wanting to sell this so I can finish my 65 coupe project.
Asking 6500 for all of it.
Located in Hendersonville
615-390-3506
Thanks,
Joey
Discussion Starter #10
needle bearing c4 Kevlar clutches everything inside is aftermarket. Was built to go behind the 408 with all the nos. Here are some pics. It hasn't been run since it's been built.
1 - 11 of 11 Posts
