21 - 40 of 45 Posts
Hey guys, I have a few things forsale.
Reproduction dash pad for 65 in black, new in its box - 130$
New headliner in black for fastback 65, new in box - 30$
Black sun visors, pair 64-66, new in box - 30$
Steering linkages from 65 mustang includes idler arm, idler mount and center link. Not sure if it is original but i had removed it to install a rack system. The idler ball joint seems to be in tact, needs to be cleaned up - 20$
Custom Quick Fuel 4777C Carburetor
I'm selling my custom calibrated 650 DP that I had on my 67 Mustang. Reason for selling is because I'm going to something different.
Calibration sheet provided to buyer.
$220.00 obo + shipping
Located in Brampton
P.S. I will be posting many more items over the next little while (suspension, T5, 8" posi with 411, etc)
Many Different Things from my 67 Mustang
Not a lot of miles on these parts:
5 speed conversion package:
WC T5 transmission, Bellhousing, Clutch Fork, block plate, Throw out bearing
Cable clutch kit from Mustang Steve
Centerforce Billet steel Flywheel 157T (28oz)
4" Aluminum Driveshaft
King Cobra Clutch and pressure plate
Slik Stik shifter and handle from Modern Driveline
Tranny mount, speedo cable, bolts, etc
Total = 1350 obo
Flaming River long shaft steering box 16:1 ratio = 260.00 obo
Roller Idler Arm from OpenTracker for 67-68 mustang = 50.00 obo
MSD 6AL = 120.00 obo
Equal Length Long tube headers that work with Zbar = 120.00 obo
20 inch rad that does NOT leak = 60.00 obo
6 blade clutch fan = 40.00 obo
4x KYB GR-2 Shocks = 60.00 obo
Front Disc brake calipers = 60.00 obo
8" housing and axles = 100.00 obo
8" center section with open 2.79 gears = 75.00 obo
I have the following for sale:
1965-66 Dashes direct dash pad. NEW in Box. BLACK - 100$
1965-66 head liner for fastback NEW in BLACK - 20$
1965-66 sun visors - New in BLACK - 25$
1965-66 USED manual V8 steering center link - 20$
1965-66 USED but feels tight idler arm - 20$
Rear sway bar by ADDCO - 100$ Never installed. It is the adjustable kind that fits under the diff. I have decided not to install this.
Make an offer
WC T5 transmission = 350.0 obo
Bellhousing, Clutch Fork, block plate, Throw out bearing = 70.00 obo -------SOLD-------
Cable clutch kit (no cable) for 1967 Mustang from Mustang Steve = 90.00 obo ------SOLD------
Centerforce Billet steel Flywheel 157T (28oz) barely used = 180.00 obo
King Cobra Clutch and pressure plate barely used= 125.00 obo
Slik Stik shifter and Hurst handle from Modern Driveline = 180.00
MSD Multi Step Retard = 100.00 obo
4x KYB GR-2 Shocks = 60.00 obo-----SOLD------
Plastic heater plenum = 10.00
1967 Export brace = 30.00 obo
Original crossmember under the engine for V8 = 40.00 obo
Brake pedal for power brakes = 40.00 obo
Z bar, rod and bracket = 50.00 obo
1967 original strut rods (needs rubber bushings) = 60.00 obo
3.5" Autometer tach = 75.00 obo
4sp transmission crossmember = 30.00 obo
WC T5 transmission = 350.0 obo-------SOLD------
Slik Stik shifter and Hurst handle from Modern Driveline = 180.00-----SOLD------
Brake pedal for power brakes = 40.00 obo-------SOLD------
Z bar, rod and bracket = 50.00 obo-------SOLD------
1967 original strut rods (needs rubber bushings) = 60.00 obo-------SOLD------
Centerforce Billet steel Flywheel 157T (28oz) barely used = 180.00 obo -------SOLD------
MSD 6AL = 120.00 obo -------SOLD------
8" housing and axles = 100.00 obo -------SOLD------
I know this an old thread:pirate:, but do you still have any parts left? Where are you located in Ontario?
Yes I have a few things left. I think this is up to date but if you tell me what you are interested in, I can look to see if I still have them. 'm located in Brampton.
I'd be interested in the export brace and headers if you still have them...I bought shorty hedmans and they don't meet up with my magnaflow pipes. I could pick the items up. I'm in Kingston
I will take a look for them as probably put them above the garage. If I didn't say sold in my add they are around the house.
I will let you know soon.
Scott
21 - 40 of 45 Posts
